Re: i-4 international
Posted by plumb on March 15, 2008 at 17:11:03 from (64.136.26.235):
In Reply to: Re: i-4 international posted by Haas on March 15, 2008 at 10:38:04:
ihave the axle removed from tractor and the hub is removed from the axle.the pin just goes down in the spline in the axle ,it does not go in a hole in the axle.it looks like the pins purpose is to keep the spacer from turning. the spacer has to come off before the axle carrier cap #31 can be removed i need to know if the spacer is pressed on or screwed on .i put it in a press and applied pressure but it didnt move any i need to know if i am going in the right direction
