Re: How much is too wear on ring gear?
Posted by Jesse on March 17, 2008 at 08:02:32 from (216.69.63.254):
In Reply to: How much is too wear on ring gear? posted by Paul Shuler on March 17, 2008 at 05:20:46:
I may be shot for saying this, but I say as long as it starts and runs, it should be no problem. A cub is easy to hand crank. Splitting a tractor to replace a ring gear is a headache. An example is that the cost of the ring gear for a Super A is about $30--a good used flywheel is about $135. A bendix costs about $40. Handcranking is easy, providing your points and plugs are good. In my case, by the time you split a tractor (like a Super A) or in your case a Cub, you have labor in it and you have to replace the fluids (hydraulic), which is costly. If you have the time then no problem. My suggestion is that if you have a hand crank, then you can use that little tractor for many more years until you have to worry with replacing the gear. At the very least, you can put a 12 volt coil on it(for that extra juice to the starter, buy a bendix ever so often..sit back, and don"t worry too much).. How much is too much wear? I agree that if all the teeth are gone, then it is time to replace it. If this was a larger tractor, then this is a whole different story.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
