Re: How much is too wear on ring gear?
Posted by tractorsam on March 17, 2008 at 13:51:26 from (71.7.203.35):
In Reply to: Re: How much is too wear on ring gear? posted by Jesse on March 17, 2008 at 08:02:32:
I won't disagree that hand cranking a good working tractor is usually fairly easy but it's not the solution for everyone. Splitting a tractor is not that difficult a job once you have a little bit of experience and ambition. Also you can get pretty creative on the tools required for the job. A couple of weeks ago I split a 140 with a stuck clutch and had it cleaned up and back together again within four hours. Prior to that I had replaced a frost plug behind the flywheel on a Super A which took a little over six hours because I had to remove the flywheel and it had cultivators and other such on it. When I first got into this hobby if I figured that if you had the tractor split replace all the seals and the clutch plate while you're in there. Now I just fix what really needs it because splitting it again is no big deal. tractorsam
