How bad is this
Posted by Pat-CT on March 20, 2008 at 13:19:23 from (68.110.205.165):
i drained the oil out of my h's rear end again and i found some metal shardes in there i looked in with a flash light and saw a hole the size of an apple in the front most wall which is pretty thin but now the H leeks oil fast around hydraulic pump shaft that comes out of the rearend so how bad is this can i jsut put rtv around that and see if it helps theres no whole stright threw but it does go into like a second wall or somekind of area so how bad is this ive used it sence with no problems except for the oil leaking
