Re: How bad is this
Posted by Janicholson on March 20, 2008 at 13:31:07 from (199.17.6.122):
In Reply to: How bad is this posted by Pat-CT on March 20, 2008 at 13:19:23:
The oil is common between the two areas. If it is leaking, it is the Hydraulic pump coupling drive (front of the countershaft in the trans) that is leaking. This can be replaced through the inspection cover (with the pump out) by taking the drive coupling out (housing drained) then removing the coupling (lefty loosy) with a hard steel square to turn it with (serious turning required). then it is obvious. JimN
