I suggest that you rebuild the mag. That will produce a hot spark and make it easier to get running.
Buy a new coil, condensor & points from YT (this site) and install them. This should produce a spark that wiil jump 1/2 inch. You can test your mag before and after rebuilding it by cutting a 3/8 inch socket extension in half and put it in a drill. Find a 3/8 inch drive socket to fit the nut on the drive end of the mag and use the drill/extension to spinn the mag.
When you take the mag off, note where the distributor is pointing(1 o'clock, 9 o'clock etc.) and do not turn the engine before you re-install the mag.
While you are at it, drill a small hole in the back of the mag housing and connect a grounding wire to the condensor. Then connect this wire to a one-wire on/off switch from a H or M. This will make it easier to kill the engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
