You can't have both at the same time, but you probably understand that.
What needs to happen is the flow to the loader needs to be blocked off in order to use the rear remote. A simple shut-off valve in the line to the loader cylinders will achieve that.
What tractor are we talking about here?
One way or two way hydraulics on the loader?
One way or two way hydraulics on the remote?
The best way to have a rear remote and a loader is to have two separate valves to control them. If you're talking about a letter series tractor with a belly pump, that would be in addition to the liftall valve on the belly pump, because that valve would be used to feed the other two valves.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
