Scotty: The two holes closest the axle(one each side of axle) on all these final drives have a very thin bottom. Probably less than 1/4" thick. It is very easy to thread in too long bolt and break the bottom out of the hole. When Larry had the pans off, he could have seen this as a break in the casting. Usually they break enough so 5/8 has an 1-1/2" diameter on the inside wall. Doesn't really weaken the final drive, my 130 has been that way since 1961. You do have to keep a bolt in that hole so it won't leak either way.
I make a practice of keeping well lubricated bolts in all those holes whether I'm using them or not. It keeps the threads clean should you ever wish to use them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
