Re: Farmall A Final Drive Level Check Plug??
Posted by ScottyHOMEy on March 25, 2008 at 16:48:09 from (71.241.213.254):
In Reply to: Re: Farmall A Final Drive Level Check Plug?? posted by Larry Ed on March 25, 2008 at 16:31:11:
Okay, I've been out fora look. the 5/8" hole, which would be at the very back isn't an issue. It goes all the way thropugh the casting to take anut washer and bolt to carry the weight of the drawbr.
Ahead of that, though, is the 1/2" hole that takes just a bolt that holds the angle for the front of the drawbar. It's located just behind the cap over the bearing on the bull gear, at about the same level as your fill plug. Like I said earlier, I thought this was a blind hole with a bottom, but it's possible, where it is above the level of the pan that it's threaded all the way through or, as was suggested above, somebody wound a bolt in there and poked it through. Poke a broomstraw or something in there and see how far it goes in.
Is this happening on both sides? It might explain why they were dry.
The bolt that goes in there if you have a drawbar is 1-1/2" long. If you're not gonna mount a drawbar, I'd plug the hole with one that's shorter, say 1".
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
