560 Hydrualics
Posted by ITFormulaGuY on March 27, 2008 at 06:33:57 from (206.137.30.217):
Can someone send me a picture of where the Hydrualic pump is located on the Farmall 560 Gas. Hydrualics were working fine, i serviced the tractor put new oil and filter in place and after using the loader to load some scrap metal the hydrualics are almost non-exsistant. There is not enough power to lift a disk or the loader. the slower you run the tractor the more the hydrualics seem to work but are still useless. if you run the engine at a higher idle the weaker the weaker the hydrualics are and leak down very quickly. Any tips or insight would be great as i am used to H's and M's! Thanks again!
