Re: 560 Hydrualics
Posted by Rootsy on March 27, 2008 at 09:03:06 from (24.176.33.123):
In Reply to: 560 Hydrualics posted by ITFormulaGuY on March 27, 2008 at 06:33:57:
Left side of tractor directly across from the filter. Beneath the cover that is behind the clutch & TA linkage.
When you replaced the hydraulic fluid you did you Hytran didn't you?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
