Need 706 diesel advice needed
Posted by tjh72 on April 04, 2008 at 12:58:21 from (65.28.253.238):
I have a 1967 Farmall 706 with the German Diesel in it and I am having a charging problem. I tested the batteries by themselves. Each battery reads 6.4 volts when the tractor is not running. You start the tractor and one battery reads 7.4 volts and the other battery reads 6.6 volts. Then you test both batteries together and that reads 13.7 volts. So based on this I think the alternator is OK. Do you think it is a bad battery or more of a volt regulator issue, or maybe something else? Your thoughts are appreciated.
Thanks,
TJH72
