Posted by old on April 04, 2008 at 21:15:40 from (4.244.220.185):
In Reply to: A sticking posted by HicksDale on April 04, 2008 at 19:19:54:
Throw the WD-40 away it not made for what your doing and will not work. Fill the cylinders with transmission fluid and let it sit a couple days, be sure you put the plugs back in. Then after a couple days pull the plug out and the engine will probably spin over just fine. What you have is a new tight engine and you let it sit and it got water in the cylinders from condensation and thats why it locked up/ got tight. Also to help keep it from doing that again run a qt. of ATF in 5 gal. of gas and that will help keep it loose
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
