Re: Farmall 706 LP tractor
Posted by redstate on April 06, 2008 at 09:25:48 from (74.38.144.53):
In Reply to: Re: Farmall 706 LP tractor posted by martin simmons on April 06, 2008 at 07:37:21:
third party image
third party image
If was me, I would just leak out the moisture and if you get it going and back to your place and everything seems like its going to work, then go ahead and change everything (filters and oil). You would leak it out before you try anything just so it doesnt get mixed up again, and even if you dont get it started and pull it home, that moisture will still sort of mix. If you use the propane bottle to get it propane, here is an example how you might do it. The factory valve (liquid) losen the fitting, make sure the two valves are off, if my pitures came through, you can see on the bottle there is a series of fittings and a propane tube. hook the tube into the factory fittng on the tractor. You may need another fitting. I would think that you could get the fittings and tube for under $10. The bottle on my tractor is obviosly something added on but the same principle, the tube goes down to a regulator and then to the carb. I hope this might help, and be careful.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
