Re: advise on clutch replacement?
Posted by CNKS on April 17, 2008 at 09:09:40 from (216.144.104.128):
In Reply to: advise on clutch replacement? posted by bjc on April 17, 2008 at 08:39:12:
www.binderbooks.com. Yes it's heavy. I replaced the clutch in my 460 hi-utility (38 inch rear tires), otherwise about the same. But, I did it after I removed the engine for an overhaul. In my opinion, if you don't have the proper stands (I didn't), you should block the rear and roll the front away. You may be able to support the front with an engine hoist, but it will have all the weight it wants.
