Re: Need more help w/ 140 belt pulley
Posted by Hugh MacKay on April 20, 2008 at 18:02:11 from (209.226.247.156):
In Reply to: Need more help w/ 140 belt pulley posted by orangepower on April 20, 2008 at 12:23:35:
orange power: Just because it had one shim in the doner tractor, doesn't necessarily mean one shim is right for your tractor. Through the fill plug hole you should be able to see the right angle gears. IT calls for heels of gears to be in register with one another, and back lash between 0,004 and 0.006. Best gauge for that is piece of pop or beer can wall into the gear mesh.
The actual pulley shaft has two bearings, and the unit will have to be removed from tractor for rebuild. The whine is very likely bearings, however I'd check the gears first, they can whine too it not meshing correctly.
