Need more help w/ 140 belt pulley
Posted by orangepower on April 20, 2008 at 12:23:35 from (64.136.27.227):
I got everything installed and when I engaged it, it made a whining sound. Could the gear from the drive shaft not be meshing correctly with the gear inside the pulley housing? The donor tractor I got the drive assembly from had one shim between the housings so I put it back on my tractor that way. I see there is a bearing out on the end of the shaft where the actual pulley attaches. Maybe it could be worn enough to be noisy? How do I get this bearing out? Thanks for any advice and help.
