Re: Need more help w/ 140 belt pulley
Posted by Haas on April 20, 2008 at 18:06:40 from (12.65.6.234):
In Reply to: Need more help w/ 140 belt pulley posted by orangepower on April 20, 2008 at 12:23:35:
If the shaft does not have play, the bearing is likely OK. I think some whine would be normal. If it is very loud, it may be the gear or the bearing. There are two bearings on the belt pulley shaft. The one nearest the pulley will come out once the bearing retainer cap/seal holder is off but it may be hard to get it to come out. I don't know if it is pressed in there or not. To get the other bearing out, you will have to remove the shaft which requires removing the pressed in plug that is in the housing on the side opposite the pulley. I'd try adjusting the gear lash before I messed with the bearings unless you have shaft play. You need to get a manual that tells you how to adjust the gear lash.
