Re: Farmall A / Fuel Tank Needed
Posted by Glynn Moore on April 24, 2008 at 10:13:04 from (216.81.102.142):
In Reply to: Re: Farmall A / Fuel Tank Needed posted by Andrew Z on April 24, 2008 at 09:51:11:
I agree with others, I would clean the tank good then apply the liner x 2 coats since you have a leak-- The quart size can is plenty for 2 coats. I've done many over the years with excellent results-You also eliminate the rust problems this way-One of the first things I do when I start with another old offset farmall is to clean
and line the tank in this manner--Glynn
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
