You should have no problem with using tank coat in that tank, i have done an M, Super C and a B all have a baffle divider and never had a issue, if you tank is not that bad i sure would clean it out real well, on how to do that just type that inot the archives and it should give you many hits on how to do that, and then apply the tank coat. the tank coat is sure alot cheaper than a new tank, i would give it a try if you tank doesnt have great big holes in it, then can be reapired with JB weld or real weld etc. Just my thoughts....
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
