2 things: 1 - What year is your tractor? A '39 or '40 has a different tank than a '41 and later. It has to do with the Dzeus fittings that hold on the early hoods.
2 - I've used sealer in my B tank. It also had leaks where the baffles are spot welded on, under the bottom bracket. It's been good for 10+ years now. You have to be generous with the sealer and put in multiple coats, but it does work.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
