Farmall A / Fuel Tank Needed
Posted by Kendog on April 24, 2008 at 09:46:13 from (64.65.209.67):
I'm in need of a non-leaker. Shame too because there's a bit a father-in-law connection to this one. Anybody have one on the shelf?
I would use the Red-Kote sealer, but after a direct discussion with Damon Industries' tech, he says it's not recommend for any baffled tank.
Any help? Thanks, Ken / ken@superfetch.com
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
