Re: H Carb Cleaning
Posted by RustyFarmall on April 26, 2008 at 06:59:09 from (209.152.78.71):
In Reply to: Re: H Carb Cleaning posted by Tom Windsor on April 26, 2008 at 05:33:56:
Tom, sometimes there is crud lurking down below where that tiny little brass idle metering jet lives. You might first try running a very small diameter torch tip cleaning wire down through the jet. If that doesn't get it, you'll have to remove the idle metering jet to get access to the crud. The jet most likely will break off, and then you have even more work, but it can be done.
