Re: Problem with newly overhauled Cub Engine
Posted by El Toro on April 27, 2008 at 03:52:25 from (205.188.116.73):
In Reply to: Problem with newly overhauled Cub Engine posted by Gale Roberts on April 26, 2008 at 22:58:22:
Make sure your plug wires are in the correct firing order on the mag's cap. Hal
2-1
4-3
PS: You should bring No1 piston to TDC on the compression stroke and then see where the rotor is pointing. It should be at the No1 plug tower on the cap. Did you remove the cam & crankshaft?
