Problem with newly overhauled Cub Engine
Posted by Gale Roberts on April 26, 2008 at 22:58:22 from (64.12.116.73):
I just overhauled my 1948 Cub, Valves and seats resurfaced new valve springs, with Valve clearances set at .013, all new Crank and Rod bearings, new Piston Rings,,new champion D18y Spark plugs set at .025.I got it running but it has no power and sounds like it is late on time but I checked the Magneto all over installed new Points, Condensor, coil, rotor,Cap, and new Spark plugs. It has good spark and I timed it according to the manual. The two center cylinders seem to run colder the end ones like it is not firing as good on the middle cylinders. The center spark plugs feel much cooler to the touch after running. I installed a new kit in Carburetor and set float to the manual specs and have plenty of gas to carburetor. Can anyone tell me what might be my problem. Thanks....Gale
