Re: Problem with newly overhauled Cub Engine
Posted by Edpap on April 27, 2008 at 07:29:49 from (74.33.247.63):
In Reply to: Problem with newly overhauled Cub Engine posted by Gale Roberts on April 26, 2008 at 22:58:22:
Hello Gale,
I would do a compression test to eliminate a valve problem. then I would check your manifold if you are sucking air on the center cyl's it could do this. are the plugs wet on 2 and 3 ? maybe bad wires.
Good Luck Ed
