SA gasket OH set- simple question
Posted by P and R Pete on May 01, 2008 at 18:11:02 from (74.212.12.204):
The overhaul-gasket set I got for my Super-A included these two items.
third party image
The rubber seal is obvious- it's for the touch-control hydraulic pump, though it's odd it was included, because everything else I needed to overhaul the pump I had to get as a different gasket set, and I also needed to get a separate gasket set for the hydraulic block. This rubber seal was the sole thing included for the hydraulic system in the OH set. Go figure.
Turned out my pump uses a rubber O-ring anyway, so the seal is extra.
My question is what does the felt gasket fit? I saw no obvious place during the engine overhaul, nor have I seen a picture of a hydraulic pump that uses a felt seal.
Just wondering.
