P and R Pete said: (quoted from post at 18:11:02 05/01/08) The overhaul-gasket set I got for my Super-A included these two items.
The rubber seal is obvious- it's for the touch-control hydraulic pump, though it's odd it was included, because everything else I needed to overhaul the pump I had to get as a different gasket set, and I also needed to get a separate gasket set for the hydraulic block. This rubber seal was the sole thing included for the hydraulic system in the OH set. Go figure.
Turned out my pump uses a rubber O-ring anyway, so the seal is extra.
My question is what does the felt gasket fit? I saw no obvious place during the engine overhaul, nor have I seen a picture of a hydraulic pump that uses a felt seal.
Just wondering.
They are governor seals. The felt one goes on the lower shaft that runs to your carb shaft and the press in seal goes on the top shaft that comes from you throttle lever. If you need any more help just let me know.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
