Re: Farmall A need some advice....
Posted by francoisc27 on May 03, 2008 at 18:44:41 from (68.159.112.4):
In Reply to: Farmall A need some advice.... posted by tn terry t on May 03, 2008 at 13:50:23:
Janicholson said: (quoted from post at 19:12:41 05/03/08) It will work fine on 6v pos ground. if pulled to start the mag will rotate well enough to make fire. Pull it in 3rd gear at about 2 to 3mph, no faster.
Be sure to run a piece of wire up into the hole to the tank to assure fuel flow there.
The wheel might be loose on the rim, and that will make the noise.
The solenoid (relay)is not needed. a starter switch on the starter, with a pull rod, or a heavy amp starter switch at/next to, the dash is good also. John T troubleshooting guide, and other infor in the "search for" box will do wonders. this link is for the diagrams of choice. Stay with 6v on this one, withsingle "o" gauge wires to the starter and ground. JimN
Bob M diagrams
Thank you very much, I will try to see if it will start tommorrow,
Is there a way that I can test the coil that is in the magneto?
