One easy way is to pull start it. If it has spark, it should run! It is possible to use an ohm meter on coil windings, but even then, proof is in the spark. not the readings. Look up magnetos in Google. there will be diagrams detailed enough to use an ohm meter. Make sure it has oil in the crankcase, and watch the gauge to be sure it gets pressure up. I would pull it W/O the Mag operating (shut off) until oil pressure was shown on the gauge. There is no reason to ruin a good engine If it needs to be primed. To prime, use as pump oil can and pump oil into the oilpressure gauge fitting hole. as it begins to be filling the passages, it will get harder to pump. Sometimes a small rubber tube is needed to get a seal at the oil gallery to oil can spout. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
