Re: Farmall A leaky axle
Posted by RJV on May 04, 2008 at 02:52:23 from (75.179.27.97):
In Reply to: Re: Farmall A leaky axle posted by riverbend on May 03, 2008 at 06:23:39:
When I opened up the level plug, about 1/4 - 1/3 cup of fluid came out. I know when tractors sit outside, water will get in through the gear shift. Do you think I was leaking out through the axles because it was over full?
I drained the thick, brownish stuff out and filled it with new gear oil to the proper level. I will be currious to see if it still leaks.
