Re: 656 w/single remote lugs engine in 1 position only?
Posted by TX656 on May 10, 2008 at 09:06:20 from (71.48.165.214):
In Reply to: 656 w/single remote lugs engine in 1 position only? posted by TX656 on May 10, 2008 at 06:52:33:
Thanks, I'll check that. Since I first posted I have been out trying more things.
I took off one of the quick connect tips so I had an open hose on one end. Put the open end in a bucket. Tried the remote and fluid pumped into the bucket about like a garden hose 1/2 open. I was expecting more. I stopped after about 1.5 gallons. Poured fluid back into tractor and tried again. Same thing. Switched to other outlet, same thing...and then everything changed. Finally PRESSURE!
The hose flew out of the bucket pumped about the same 1 gallon in about 1 second. It covered the workshop wall up to about 10', toolbox, floor etc.
What is this all a sign of? Did some obstruction in the valve finally break lose? Is this a sign of internal valve problems and should I tear it down? Should I see if 'results' are repeatable? Thanks everyone.
