Re: 656 w/single remote lugs engine in 1 position only?
Posted by charles todd on May 10, 2008 at 21:33:10 from (205.242.95.140):
In Reply to: 656 w/single remote lugs engine in 1 position only? posted by TX656 on May 10, 2008 at 06:52:33:
One day I will learn how to post in Modern View...
If it is like the '06 series (like my 504) the valve(s) are on the right hand side, under the seat. These valves have a "float" position all the way forward. You may not notice this because the detent balls, spring, and unlatching piston are stuck from rust and corrosion. These parts are not in oil and are behind the "pipe nipple" screwed into the rear of the valve.
Valve on Bench
third party image
Valve Mounted
third party image
third party image
I rebuilt my valves and now they will lock in the rear, forward, and float positions. When I am using my loader and want to apply down pressure, I have to be careful. There is a VERY short throw on these valves and sometimes I hit float and loose PSI.
Try this; push the lever forward a small bit and watch the gauge, then a little more, then a little more. You should see the PSI load up then drop while preforming this exercise. If it is stalling, the relief may be sticking or the check ball in the valve is stuck.
Valve Parts Diagram
third party image
If I can be of further help, email is always open. I learned a lot during the rebuild of these valves. I have two more I plan to rebuild a sell at a later date.
