Posted by Dan Swanson on May 11, 2008 at 15:39:42 from (63.172.252.161):
Posted last weeek that I had a lot of chatter in both brakes on my 856. Was suggested I clean out the small holes to let the dry matter out. Crawled under the tractor and use a small wire to open them up on the left side that chattered the most after I opened up both holes I got some black dirty wet oil on the wire. The holes are clear now no oil actually ran out of them. Just a drip or two. This tactor has several minor leaks above and ahead of the brake covers. DOes this mean there is a seal somewhere that is letting the oil into the brake disks? Also, as I mentioned before when I pulled the transaxle plugs they seemed to be way over full but I didn't drain them down to the top plug level. Could some of this oil be causing the problem from being over full? Thanks, Dan
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
