Posted by mazemeister on May 13, 2008 at 18:59:33 from (24.188.91.120):
In Reply to: '69 856 brakes.... posted by Dan Swanson on May 11, 2008 at 15:39:42:
I just went through a similar procedure with the 806- I think the brakes would be the same on the 56. As for the brakes- there are a couple o rings and i think an oil seal to keep the oil in the trans and the brake discs dry. Your IH dealer would have a kit for that. If your disks are oil soaked, might as well replace them too. Not sure if it would cause chatter, but I replaced discs and o rings, now have brakes on both sides- RH never used to work.
On the axle housings- I changed the oil on our other 806 a couple weeks ago, pretty sure it was the first time it was ever drained. I took out a good 4 gal between the two sides, book calls for 5 qt each. It doesn't seem like it's hurt anything to be over full- that won't affect the brakes anyway.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
