Re: Super M Seal Removal?
Posted by teddy52food on May 11, 2008 at 17:45:35 from (209.237.111.169):
In Reply to: Super M Seal Removal? posted by Smith1000 on May 11, 2008 at 08:42:09:
Put a chain around the rear of the engine and support it with a cherry picker. then remove whatever is holding the plate and get it out of the way.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
