Posted by Smith1000 on May 11, 2008 at 08:42:09 from (12.213.112.39):
Is there a way to gain clearance to remove the plates for replacing the felt seals for the engine (behind the flywheel)? There is a top and bottom half. I have removed the bolts from each plate, but cannot remove the pieces due to the lack of clearance. I would like to avoid removing the whole flat metal housing piece just to remove the plates in order to replace the felt pieces. I am replacing the clutch and would like to replace the felt pieces behind the flywheel while I am in there. Also, does anyone know the torque spec for these bolts? Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
