Posted by Rock2000 on May 11, 2008 at 17:47:16 from (76.194.83.84):
We had an issue with our H stalling after a few minutes of running, so it seemed like a clogged fuel passage somewhere. I figured this was a good time to take the carb apart and use the rebuild kit I had bought last year. I blew everything out and installed it, and not only does it still stall, but worse it has a large leak once you let it sit for awhile.
As far as I can tell the float looks good, but apparently it's not closing the carb fuel inlet, because I see leaks from around the gasket (between the carb halves), and out the carb weap hole in the air inlet. I tried putting the old fuel inlet valve back in and it still leaks. What the heck!?!?! What am I missing? It's not a small leak.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
