Posted by Bo Bradshaw on May 11, 2008 at 19:05:59 from (74.232.157.181):
In attempting to install my newly purchased factory road gear, I cannot determine which end of the sleeve that fits over the top spindle should be nearest the transmission. Also, how do you remove that top shaft? Mine needs a little filing done to it to make the sleeve fit and after removing the cotter pin, I can"t stop the shaft from turning long enough to get the big nut off which I assume will let me get the shaft off. Also, the road gear backer plate hits a transmission top fill check plug. Do I grind off the plug or put a differnt style in? Bo
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
