I may just leave the seal and put it back together. About the only way I could support the engine is to build an overhead support with 6X6s and drop a chain down around the back side of the engine. I could use a hoist on it.
I would still be concerned about the rails being loose. The weight of the engine in the rear is currently resting on 3 bolts at the bottom that attach to the large round metal plate. The metal plate is somehow attached to the rails-although the large bolts are out of it, so I am not sure how it is attached because the large bolts are out.
In retrospect, it would have been better to hang the engine rather than support it on the side rails.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
