Re: Super M Seal Removal?
Posted by Smith1000 on May 13, 2008 at 18:26:43 from (12.213.112.37):
In Reply to: Super M Seal Removal? posted by Smith1000 on May 11, 2008 at 08:42:09:
Thanks. This worked. I dropped the oil pan and was then able to tap the bottom lip out through the rear. The plates dropped down. The seals definitely needed replacement. I'll cut the other paper gaskets tomorrow and will piece this back together. I'll then be able to put the flywheel back on.
