560D TA slipping
Posted by scenic acres on May 13, 2008 at 18:56:03 from (66.173.38.90):
I recently had to replace the TA clutch, pressure plate, and throwout bearing. The bearing was completely gone and wore grooves in the pressure plate. Well the TA worked fine for a while and now when I pull the lever back it slips. You can apply the brake and it does not go anywhere. As I allow the lever to move foward the tractor takes off or if i hold the brake enough it will kill the engine. What should I do, is it just out of adjustment?
