Re: Farmall A Mower Bogging Down
Posted by Hugh Mackay on May 15, 2008 at 08:34:09 from (209.226.247.52):
In Reply to: Farmall A Mower Bogging Down posted by Whitley County on May 15, 2008 at 08:04:46:
Tom: I agree with Rusty, a good working Farmall A or SA will burn the belts off before it ever lugs down. If the blades are sharp, grass 10" tall wont affect the mower or tractor. If your blades are dull the belt and pullies will get hot no matter how tight they are.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
