Re: battery terminal meltdown today- stuck solenoid??
Posted by trucker40 on May 18, 2008 at 09:49:39 from (69.152.34.54):
In Reply to: battery terminal meltdown today- stuck solenoid?? posted by ironandsteel on May 17, 2008 at 18:31:46:
If you can take the solenoid apart,it will probly have places where its tried to weld itself to the plunger.To fix it grind it smooth,I have even brazed it back up and ground it flat,or if you can turn it over.On the starter,it sounds like its dragging.I dont know where you can get an amp guage that you put on a starter cable,but if you can find one I bet its pulling 400 amps.That would mean it needs to be rebuilt.Probly the reason its wired for 24 volts,it got to where 12 volts wouldnt crank it.
