Posted by ironandsteel on May 17, 2008 at 18:31:46 from (12.26.114.108):
Today I had a little problem on my new 1963 IH 806 that I've been discussing here.
At the moment, this thing is wired for 24v and I believe has the original 12v starter. So, it spins that big diesel quite smartly.
I had been driving it around and shut it off. When I came back a few minutes later I hit the starter. It turned over a bit and I let the starter off too early- it didn't quite start.
When I pressed the starter again, I think I just bumped it, and I looked down and one of the battery terminals was arcing and sputtering molten lead where it had melted the battery clamp, which acted like a fuse.
When I tried touching the now severed cable back to the remains of the battery clamp, it was like a welder- there was basically a dead short, or maybe the solenoid was stuck on.
I went over and tapped the solenoid with a piece of rebar to unstick it and this seemd to work. I touched the cable to batt terminal again, and it was back to normal again.
So- just to get it started so I could get home (this happen at the neighhbors farm), I vice gripped the battery wire onto the remains of the clamp and tried to start. It kindof felt like when your battery is real low- a click and shudder. But then when I let off the starter button, I was back to drawing lots of current and I quick yanked off the vice grips.
I just got this tractor a week ago. And there is no charging system on the batteries yet- I've been starting it all week on the charge that was there.
Tonight I put chargers on both batteries and I'll try to get her going tomorrow. I'm thinking that the batts got worn down to a point where they couldn't turn it over after a couple rounds of stuck solenoid and welding.
The question is this- should I pull the starter and see if there is something I can lubricate in the solenoid? I don't know if it is possible for mere mortals to get the solenoid apart or not.
Maybe just to get it going, I'll bypass the solenoid.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
