Re: Putting Rear wheel weights on an 856....
Posted by Mark from WI on May 18, 2008 at 21:00:38 from (207.118.224.67):
In Reply to: Putting Rear wheel weights on an 856.... posted by Dan Swanson on May 18, 2008 at 20:45:47:
Just go but some 3/4 inch threaded rod and cut them into 8 equal lengths and bolt them to the hub on both out and inside and then slide your weights on and put a washer lock washer and a nut to hold them on.
