Putting Rear wheel weights on an 856....
Posted by Dan Swanson on May 18, 2008 at 20:45:47 from (63.172.252.161):
Have a set of 8 -1 pece and two piece weights that came off an 806 with 34" and I want to put them on my 856 with 38". After measuring the mounting holes in the wheels on both tractors they are the same dementions. The hole in the wheels are 16 1/2 OC cross ways and 12" OC hole to hole. The 1 piece weight holes are 15" OC cross ways and 10 1/2 " OC hole to hole.
I know this is a simple matter but I can't figure out how to get the first weight installed so the rest will bolt up. I didn't go thru the whole stack of 1 piece weights but is there a starter weight I need to use that lines up with holes on the wheel or do I start with a couple of two piece weights? I have looked in my owners manual and the IT manual but there is no mention how to mount them other than bolts sizes needed. Attached are a few photos of the two tractor wheels and of the weights. I did notice some of the one piece weightsare 8887-D 1 and some are 2's and a couple are marked with just a W-9. Any help would be great. Or a photo would work too.
Thanks Dan
