Re: Putting Rear wheel weights on an 856....
Posted by Lee in Iowa on May 18, 2008 at 22:05:34 from (66.172.198.110):
In Reply to: Putting Rear wheel weights on an 856.... posted by Dan Swanson on May 18, 2008 at 20:45:47:
I don"t know how they were on the 806, but the one piece weights in the picture are not IH weights. IH one piece weights are shaped just like the two piece weights in the picture and the holes will line up. You can use ready bolt to put the weights on just be sure to use 4 nuts for each weight. Or you can bolt the first weight on with regular bolts and then bolt on each subsequent weight with special square head all thread 3/4 bolts using the slotted holes on the sides of the weight. I don"t know if you can still get the special bolts from a dealer, I made mine with ready bolt and square nuts. You slide a bolt into the slot and bolt it to the already mounted weight and then bolt the next weight on with another nut. You can keep adding weights by alternating which two holes you use. Someday I"ll learn how to put pictures on here and these won"t be so long. Lee
