Re: Putting Rear wheel weights on an 856....
Posted by formerly ny bill on May 19, 2008 at 05:09:43 from (66.24.240.172):
In Reply to: Putting Rear wheel weights on an 856.... posted by Dan Swanson on May 18, 2008 at 20:45:47:
the issue seems to be how to mount them, not whether they are correct. IF they were on an 856, they will fit the 806. the wheel diameter is a non-issue. use ready bolt (try to find grade 8 or at least grade 5- i think standard redibolt is grade 2. standard will work, but 4 weights on a side is a load) and cut 4 pieces for each wheel, long enough for the wheel, nuts/washers, and all 4 weights. you may have to use the 2 piece ih sets on the inside, to clear the wheel hub. after the inside set, slide the rest on and bolt them fast. if there are 2 sets of ih weights, i'd put 1 set on the outside of the stack and most people won't even notice that some aren't standard ih.
