Super M Hydraulic Reservior
Posted by David Goode on May 24, 2008 at 19:23:57 from (66.82.9.53):
Is The Hydraulic Reservior of a Stage I Super M just held on by six bolts? I see six bolts that seem to hold the "oil pan" of the reservior on. Then how hard would it be to remove the old pump? Is it direct drive from the engine? Thanks for any help.
-David Goode Coggon, IA
